Cambridge center channel speaker
hrtbeat2
How do these rate? I'm kicking around the B&W CC3 or CC6, or Paradigm or definitive tech CLR center channel speakers. Pros/cons
Thanks dan
L
Leprkon
you should match your center to your mains... same manufacturer and same model line if you can. it will give you the cleanest sound movement across the front. the rears are much less critcal and the sub can be pretty darn near any manufacturer, but thos front three really need to match.
