Praxis
Hello MDS, and thanks for responding to my initial question.
You mentioned that WMP will do just as good of an extraction as EAC. That is new information to me. Is it the WMA Lossless selection on WMP that you are referring too that is as good as EAC's ripping ability? What bit rate would you suggest without it being overkill in your opinion?
After ripping to WMA Lossless, (if this is the selection on WMP that is competive with EAC and is the one that you are referring too) how can I then use LAME to put it into MP3?
Is WMA ......? as good of a archival choice as FLAC?
If you could answer each one of my above questions I would really appreciate it.
Thanks MDS
Praxis
Thanks MDS
Praxis
