Praxis
Hello:
1. Can someone tell me when one goes into the EAC programme; then to "compression options" and then to "ID3 tags", which of the items there should I have a check mark beside? Thanks.
2. Also, when finished ripping with EAC, what is the best way to bring your album over to Nero. I ask this because when I see the listing of the ripped songs, I also see a couple of data files, plus the Nero symbol at the top. When I press on the Nero symbol it brings all of the songs over to begin burning, but it also brings those data files over. So what I did was opened up Nero first and then highlighted and brought over only the songs and left out the data files instead of pressing the little Nero symbol which was above my ablum list which brought over everything. This is a naive question I know, but someone might be able to get what I'm trying to say and maybe could offer a method which is the right way. When you reply, can you thoroughly describe what you mean, kinda like you would talk to a mentle patient, just kidding, I'm new at this and don't get the short form talk. Thanks so much,
Praxis
Praxis
