calibration LNT5271F
miggs29
All,
I have performed the calibration on my own using the HCFR software, DVE essential patterns (blue ray), and the spyder 2express colorimeter as described in http://www.curtpalme.com/forum/viewtopic.php?t=10457. I was wondering if you could please take a quick look at my data to see if things look normal or do I need to adjust things. I have not gone into the service menu in fear of messing things up, but I think I am having issues with color and I am not quite sure how to adjust it. Things like the Food network logo look a bit harsh with a lot of red. The dark scenes are also quite dark and I know have a lot of noise in the picture
Gray 10 20 30 40 50 60 70 80 90 100
x 0.307 0.313 0.309 0.313 0.314 0.312 0.312 0.311 0.311 0.311
y 0.325 0.334 0.325 0.329 0.328 0.327 0.328 0.329 0.330 0.334
Y 0.84 3.40 8.01 15.55 25.88 38.57 54.63 73.31 94.05 120.50
Delta E 5.0 4.4 3.3 0.4 1.4 1.8 1.0 1.2 2.2 4.9
Delta xy 0.007 0.005 0.005 0.001 0.001 0.002 0.001 0.001 0.002 0.005
Gamma Y3.517 8.45 15.881 25.974 38.864 54.667 73.482 95.401
ColorTemp6369 6206 6654 6418 6422 6553 6506 6486 6497 6516
red green blue yellow cyan magenta white
x 0.633 0.261 0.147 0.415 0.228 0.321 0.311
y 0.326 0.614 0.051 0.495 0.348 0.149 0.334
Y 26.052 80.135 6.327 112.991 91.704 1.219 120.613
delta E 1.9 19.5 13.6 4.3 12.7 2.4
delta xy 0.007 0.042 0.01 0.011 0.019 0.005
delta luma 1.60% -7.10% -27.30% 1.00% -3.40% -9.10%
Picture Menu
Mode Movie
Contrast 95
Brightness 42
Sharpness 20
Color 43
Tint G43/R57
Backlight 3
Color Tone Warm2
Size Just Scan
Digital NR Low
Auto Motion Plus Off
Detailed Settings
Black Adjust Off
Dynamic Contrast Off
Gamma 0
Color Space Auto
My Color Control All 15 (centered)
White Balance
R Offset 16
G Offset 15
B Offset 10
R Gain 19
G Gain 15
B Gain 26
Thank you so much in advance,
bandphan
bandphan
Its hard to say if anything is wrong due to set variance and your cal conditions. Was it calibrated in a dark setting?
miggs29
The calibration was done mostly in the dark. A lamp was on near by, but not directly in front of the TV. Should the room be dark?
