Cadence CSX-15 subwoofer for $370 after $30 coupon shipped!
Buckeyefan 1
Buckeyefan 1
They have free shipping as well.
Coupon codes:
For the CSX-15 use OFF30 for $30 off
For the CSX-12 use OFF20 for $20 off
www.cadencestore.com/ProductCart/pc/viewCategories.asp?idCategory=137
CABINET SPECIFICATIONS
* Hand Polished Gloss Black Piano Finish Front Baffle.
* 3/4" High Density MDF Fiber Construction.
* Bonded and braced at all critical joints, engineered to dampen and eliminate all vibration for transparent and accurate bass reproduction.
* Front firing subwoofer with "computer tuned bass-reflex slot port system".
* Black wood grain cabinet finish with spiked footings and floor protection casters.
SUBWOOFER SPECIFICATIONS
* High Power 15" Subwoofer.
* 2.5" Four-Layer Dupont Kapton Voice Coil Former.
* 100oz. Heavy Duty Magnet Motor Structure.
* Extended Pole Piece Technology.
* Vented and Extended Magnet Back Plate.
Double Laminated Surround and Dual Spider Suspension System.
Frequency Response: 20-500Hz
AMPLIFIER SPECIFICATIONS
Built-in Linear Class A 500 Watt Dynamic Power Amplifier.
RMS Amplifier Power: 225 Watts @ <1% THD.
* High Current Output stage utilizing 6 Ring Emitter Technology Sanken Studio Grade Japanese Transistors.
* Lowest Mains Buzz of any subwoofer on the market, guaranteed!
* High Damping Factor >400 @ 80Hz for Superior Subwoofer Control.
33KOhm Input Impedance which prevents input signal loss and insures distortion free signal transfer.
* High Grade, Minimal Loss, Tiffany Style Low Level RCA Input Jacks.
* Auto Start Turn-On/Turn-Off with Audio Signal 1mV sensitivity.
* Fully Adjustable Phase Control 0-180 Degrees.
* Fully Adjustable Low Pass Subwoofer Crossover Frequency Control 40Hz-120Hz @ 12dB per octave.
* Fully Adjustable Bass Boost Equalizer +12dB @ 45Hz.
* Independent Sub Bass Volume Control.
* Crossover Bypass Switch for Full Range Unit Operation Option.
* Slew Rate 80 volts per uS in Full Range.
* Frequency Response: 10-120Hz +/-3dB LP (10Hz-500Hz Bypass).
* Signal/Noise Ratio >110dB+.
* LED Power On Indicator.
* 110/220 Voltage Selector.
* Cabinet Size: 18.5"(w) x 17.75"(d) x 21"(h).
jinjuku
jinjuku
Moderator
Someone needs to get Cadence a decent web designer. What a horrible looking site. If I was out looking and didn't know better, they would have been crossed off my list.
I have the CSX-15 right now and will be doing a review of it very soon.
