is there a good online source for good cables for not so much money?
D Don Harris Audioholic Intern May 24, 2006 #1 is there a good online source for good cables for not so much money?
mytzen Audioholic May 24, 2006 #2 Monoprice and Blue Jeans cables have good quality at a low price. http://www.bluejeanscable.com/ http://www.monoprice.com/home/index.asp
majorloser Moderator May 24, 2006 #3 I guess the other question is, "What kind of cables are you looking for?"
D Don Harris Audioholic Intern May 25, 2006 #4 All cables! Component, Digital (coax and fiber), composite video and audio, and speaker. Looking for a good cable that looks nice and sounds good as well. Alternative to Monster cables. Thanks, Don
Sheep Audioholic Warlord May 25, 2006 #7 Don Harris said: thanks. is a digital coax the same as a sub cable? Click to expand... Yes. As well as composite video(cept its 75ohm stable). SheepStar
billy p Audioholic Ninja May 25, 2006 #8 The commom thread for good quailty interconnect cable is Belden look for that also the connector would more than likely be Canare rca.Lastly, look for that combination and who sells for less! Last edited: May 25, 2006
j_garcia Audioholic Jedi May 25, 2006 #9 Don Harris said: thanks. is a digital coax the same as a sub cable? Click to expand... Not necessarily. A digital coax is a 75 Ohm cable, which is the same as composite video as Sheep states, however analog audio cables do not have to be 75 Ohm. What that means is, not all analog cables can be used interchangably for coaxial digital 100% of the time (most of the time it will work fine, but once in a while...) because not all analog cables are 75 Ohm. You CAN use coaxial digital for composite video and vice versa, as well as for analog audio.
Tomorrow Audioholic Ninja May 25, 2006 #10 Don Harris said: is there a good online source for good cables for not so much money? Click to expand... This guy made all of mine, and they're beautifully made and inexpensive. He'll even do custom work for really reasonable prices. Check him out. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14966&item=9727143953
mtrycrafts Seriously, I have no life. May 26, 2006 #11 Don Harris said: thanks. is a digital coax the same as a sub cable? Click to expand... Can be, yes, it can be used for sub application, if the price is right Or, video cable, or plain analog audio cable.
D Don Harris Audioholic Intern May 26, 2006 #12 mtrycrafts said: Can be, yes, it can be used for sub application, if the price is right Or, video cable, or plain analog audio cable. Click to expand... So, does this mean I can use a plain analog audio /video cable for a sub as well?
W warnerwh Full Audioholic Jun 8, 2006 #14 There's good deals on Canare on Ebay. Check prices as they vary alot for the same exact cable and connectors. For speaker wire I prefer using mil spec twisted silver plated wire purchased off of Ebay. You can twist it with a drill. Locking bananas and good spades are very easy to put on. I don't even understand why someone would pay someone else to do this it's so easy. Quality connectors are my advice too. They cost more but are nice to use and don't bend or break like cheapo radio shack connectors. Knukonceptz has some nice Z banana plugs that fit nice and snug.
Brian_the_King Full Audioholic Jun 9, 2006 #15 Oh my, no one has mentioned my favorite; http://signalcable.com/index.html
