Okay so I bought a new toy last night, the famous Radio Shack SPL meter #33-4050. Hurray!
I got home and started playing with to set all my speakers to 75dB using the receiver test tone. I’ll get a “tuner DVD” soon to work on that in depth.
First finding, 75db from a sub is pretty loud compared to the rest of the speakers! Bad placement, it sounds boomy.
Second finding, in order to get the center channel to 75dB, I had to set it at -6dB on the receiver. ?!? That doesn’t make sense in my mind. Here are some basic specs for these Monitor Audio speakers:
-Fronts (RS6): Frequency Response=38Hz-30kHz Sensitivity=90 Impedance 6ohm Power Handling 120W
-Center (RSLCR): Frequency Response=45Hz-30kHz Sensitivity=91 Impedance 6ohm Power Handling 120W
Note that the center channel sits farther away but is pointed directly at the listener.
I’ve been reading about speaker cables and got a major headache out of it. My electricity class at the university was a long time ago.
Yet, cables are the only thing that is different between these speakers. I have an old set of MIT TMax terminator with coax cable for the fronts while the center uses a Z1 Monster Cable.
Could it be the MIT gizmo are robbing power?
