L
LOUMFSG
I have tried looking through the various cabling tips and guides, but I am having a hard time weeding through some of the extremely technical data to get to some good recommendations that I can use. Here are the components that I need to connect:
Panasonic TH-50PHD7UY plasma display
Yamaha RX-V2500 AVR
Onkyo DV-CP802 SACD/DVD-A/DVD-V player
Comcast HD Digital STB.
BIC Venturi speakers
I need three sets of component video cables (set-top-box to receiver, dvd to receiver, and receiver to display). Does anyone have a recommendation for good quality / reasonably priced cables that I should look for?
Also, I'll need two digital audio connections (set-top-box to receiver, dvd to receiver). Should I get optical or coax cables?
I'll also need one set of 5.1 analog audio cables. Should I get standard RCA cables?
If for any of these, if there are various quality levels (premium, "gold", etc.), where does it make sense to spend a little extra, and where are the standard cables just fine.
Finally, where is a good place to buy cables. Is Radio Shack the right place to shop, or are there better places?
Thanks in advance?
Yamaha RX-V2500 AVR
Thanks in advance?
