crux
Hello,
I recently picked up a Denon AVR687 for the Zone 2 feature and to compliment my miniature home entertainment center. I have attached a simple diagram showing my main devices and the current connections types. My main room has two front speakers and a center channel. Upstairs on the deck, I have one outdoor speaker set up as well. Just had a few quick questions:
1. I have regular digital cable (no high def). My Motorola cable box has outputs for component, s video and coax (currently connected directly to the TV). I was wondering if there was really an advantage to running the coax through the receiver instead of directly to the TV? If so, is there really a noticeable difference by using component or s video to the receiver from the cable box instead of just using the coax cable?
2. I think I have most of the video connections set up correctly. I just changed out some composite video for component. I don't have any HD inputs so no need for HDMI connections. I am wondering about audio. If I do go the route of component from the cable box to the receiver, I'm guessing I should get the coaxial (orange) audio? Obviously I should go coaxial from the DVD player to the recevier instead of stereo analog, right?
3. I also plan to buy a new laptop soon. I currently use s video to connect my laptop directly to the TV to watch movies. Do newer laptops have a better method to connect to TVs these days? I haven't heard of any componenet connection outputs on laptops, but could be missing something. Also, is the best audio still to go through the headphone jack on the laptop or is there a digital output as well?
Thanks!
Thanks!
