My question is regarding the channels that output in 2.0. Would the sound quality be better using PCM instead of Dolby or does it just send a PCM version of the same compressed sound? Also, when Dolby HD channels are sending 2-channel audio, since the bitrate stays the same, does that mean each channel is less compressed than the multi-channel 5.1 (384/2 instead of 384/6)?
Setting the box to output Dolby Digital vs PCM is the same as the analogous settings on a DVD player with the exception that the box will not convert analog audio to PCM and output over the digital out like a DVD player will (at least my Scientific Atlanta 3100HD box will not).
If you set the output of the box to Dolby Digital:
- If the source is DD 5.1 or DD 2.0, it will just send the bitstream untouched to the receiver and the receiver will do the decoding - the same as setting a DVD player to bitstream. If the source is PCM it will also just pass thru.
If you set the output of the box to PCM (mine just calls the setting 'other'):
- If the source is DD 5.1 or DD 2.0, the box will decode and downmix if necessary to 2 channel PCM.
- If the source is PCM, it will just pass thru because it is already PCM.
Regardless of the digital out setting, if the source is analog audio, you will hear nothing unless you also hook up analog audio cables and have the receiver set to Auto so it can automatically switch between digital and analog.
Don't get too hung up on the bitrates. If the bitrate for DD 5.1 is 384 kbps, it does not mean that each channel uses 384/6 kbps. For any given second of audio, each channel does not necessarily have the same amount of data. If it did, then the surrounds would be active at all times.
