MDS,
Thanks for the input. I think I am going to give the F to RCA ones a try as after futher research, using the Quickport Red RCA Compression Connector will require me to buy yet anouther compression tool, I already have three bought at one time or another for a specific installation, as the aforemention connnector will not fit the one that I have and there is no ino available on whether or not you can remove the actual connector assembly from the plactic housing to terminate it.
The F to RCA I can buy locally and the other I have to order from the US so the later will be a lot more painful to return if I have to do so.
Thanks again for you thoughts
Michael
