markw
mike c
mike c
mark, if he buys those pebbles ... you're the direct reason machina dynamica will get some more money :D
Adam
Adam
I like how they show a picture of their cable system holding a credit card. "Look, we got your money!"
F
fmw
I notice that one of Audioholics sponsor sells cable suspension management http://www.audiav.com/Cable_Suspension_System.html . Are there any new data available behind these products?
The answer is no. Like almost every audiophile "tweak" ever marketed, this one doesn't do anything other than perhaps reduce the amount of dust your cables will pick up from the floor. The fact that they buy advertising on this site doesn't change the truth. Sorry.
Rickster71
Rickster71
What's with the negativity on this forum?
Where are you going to find cable holders, that double as a credit card holder?
You could even put your car keys, and loose change in it.
:D
Adam
Adam
:D
:) Hee, hee.
markw
this one always makes me shake my head, too.
http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=NOB_C37_C
I like how they present their evidence that it works.
"The beech wood is coated several times with C37 lacquer for best sound as pointed out by Dieter Ennemoser. How can this make a difference??? Well, hearing is believing as we always say. "
Hey, I've seen David Copperfield make the space shuttle disappear, too.
mike c
mike c
wow, 485 bucks!
i've seen David Copperfield cut himself in half and rolled around the stage ... I believe! :)
"Mike has taken a bath several times today for best 'look' :cool: as pointed out by Fatty Bignoser. How can this make a difference??? Cause I F*$@!() say so!"
davidtwotrees
davidtwotrees
Presenting the Diamond Encrusted Gold Plated Bannana Plugs!
Actually, that is the same company that made the rack reviewed by audioholics a month or two ago. I was first to post something to the effect that "$5400 for an equiptment rack?!!!:eek:" which then led to an employee of the company blasting me as an idiot......then the owner came on and apologised.........but I checked this OP's link and while at the Audiav site I clicked on products.........and viola! they are selling special connectors for when a unit is exposed. Like diamond encrusted bannana plugs!
Here is the LINK
MDS
Those things are just dust caps for covering unused RCA jacks. The editor of Secrets sent me a set of six a few years back. But mine are just nickel and do not have diamonds in them.
I don't see prices for any of the products anywhere.
dorokusai
dorokusai
Machina Dynamica takes the cake for unreal audio "tweaks" and they are local to me. I've been there once and its a shame because they make a really trick turntable isolation stand. I met a guy that used their isolation platforms and if you've ever ridden a spring loaded, playground animal, that's what the gear did. It was comical to watch.
Mark
Polk Audio CS
