Cable sheath covering
Doug Olsen
Where can I purchase the same cable sheathing, wrap or whatever it is called .... As used by cable manufacturers? The outer solid tubing material, hollow inside, that in some cases looks like rubber. I want to DIY speaker cables and don't want to use the braided stuff on the entire length.
Help will be appreciated. Thanks,
Doug Olsen
Doug Olsen
Thanks Everett but this is the braided stuff and I'm hoping to locate non braided.
Regards,
Doug Olsen
You might try looking thru this thread....you're not thinking of heat shrink tubing, are you?
Doug Olsen
No, not shrink tube or braided. I don't know what it is called but it is an outer covering and looks like rubber. I have one Audioquest Midnight cable and it has the outer sheath tubing I'm looking for.
Maybe you can post a good picture?
