Buzzing in Front left speaker?
DrSunnysock
I listen to music using stereo x2, and my front left speaker seems to buzz whenever it tries to hit a certain basssy frequency. The other speakers seem to achieve the frequency fine. What's the problem? Can I fix it? If so, how?
R-Carpenter
R-Carpenter
Download Frequency sweep such as here
http://www.burninwave.com/
Play it through the speaker and try to pinpoint the buzzing sound which will be a lot easier this way then on the music. Post the results and we may be able to help you better.
On the other hand, tighten all screws first. Screw usually vibrate around 300 hz
jamie2112
1st thing is tighten the screws as sometimes they come loose....
Edit: Rcarpenter already said that sorry
Maybe that sweep frequency test will give you an idea if it is a cabinet resonance or something close to that speaker resonating?
Shock
Shock
Spray some raid inside.....darn flys get everywhere!
I would go for the tighten idea first, definetly the least intrusive.
