Apologies to all if this question has already been answered elsewhere, and I'll apologize in advance for the length of this message. I'm looking for some advice on purchasing a DVD player that will be used with a specific Panasonic plasma TV - the TH42PX20, which is a 42" HDTV plasma. I'm asking for DVD player recommendations relative to that particular model because of all of the macroblocking issues I've read about relative to different players - which Panasonic plasmas apparently exacerbate...wish I'd known before buying!
So, hoping not to compound that issue, I have up to $1500 to spend on a universal disc / DVD player. I would like to be able to use HDMI or DVI out, as the Panasonic has an HDMI input. Audio and video performance are both very important to me, as this player will be used not only in my home theater setup, but also in my primary music system.
My leading contenders at this point are the Denon 3910 and the Pioneer DV59AVi. I have read wonderful things about both players; across all of the reviews I've read, the Denon seems to have a slight edge. However, it clearly has some macroblocking issues with particular displays (macroblocking is a fault that I am sensitive to, and dislike), and it seems that my plasma will be a good candidate for revealing (at a minimum) or even worsening that fault.
I would really appreciate any recommendations experienced users might have. If any of you have specific experience with my display, I would be eager to hear which DVD players you've had more or less success with. I'm relatively brand agnostic, so very open to suggestions beyond the two player options I've already identified.
Thanks for your help!
