jinjuku
Moderator
How is it you can use a natural gas stove indoors, but not a butane camp stove?
Does one not give off Carbon Monoxide and the other does?
That is what I thought. Thx.I wasn't familiar with that, so I searched the web a bit.
As far as I can tell, butane itself isn't dangerous to burn indoors. It seems that the pressurized tanks are the larger concern. Most of what I saw seemed to indicate that it's fine to use either indoors.
With any fuel, if you have proper ventilation, you should be fine in regards to byproducts of combustion.
You mean Propane, or the small light-weight camping stove fuel?How is it you can use a natural gas stove indoors, but not a butane camp stove?
I spoke with a person at a camping supply store. My stove is for indoor/outdoor use. Just don't use it in confined spaces.You mean Propane, or the small light-weight camping stove fuel?
I was under the impression that any carbon-based fuel can give off CO if the oxygen level in the air is too low. CO or CO2, using this indoors isn't good.
What's the output of the burner? If it's too low, it might need to be lit for too long and it would deplete the oxygen supply.
