I bought a house with some speakers already installed and wired to binding posts. Up till now, I've only set up stereo audio so I'd like to know the best way to designate the built-in speakers for surround sound. The room is about 20.5' front-to-back, 22' side-to-side, and 10' high. We have a sectional sofa and I sit around 6' from the back wall about 2' to the right of center.
Left and Right speakers (vintage Magneplanar MG-I), and Center (Auvio, not hooked up) are obvious. Two small Auvio satellites are mounted on the front wall about 2' from the ceiling and about 6' apart. What kind of channel is this position typically used for? While I'm glad the wires are already in place for the three Auvio speakers, I wonder if these are worth keeping or if I should replace them with something better.
There are also two flush mounted speakers on the centerline (front-to-back) of the ceiling about 8' apart but they are 5' in front of where I sit. Should I use these for the rear surround channel even though they are in front of me? There are no speakers behind where I sit.
I haven't connected my ancient Acoustic Research sub yet and will probably replace it with some kind of powered model. There's a good place for it in the front left corner of the room. If I were going to add a second sub, there's a place for it in the back left corner of the room but there's not an easy clean way to get signal to this location.
Any advice is most welcome.
Bob
