The fact that it isnt easy is a given, I was just curious as to if the cost is practical. Not cost in time, but actual cost in components.
And... The only limitations on not knowing the size that is needed at this time is a mute point, as to im just making a general inquiry onto whether or not its possible in terms of cost and ability to manufacture/build.
And.. as well if you go big then you wont have issues of shooting to low, except with space constraints. However I think smaller units where space is that big of an issue, like behind a piano bar for a solo artist, that would be a whole separate PA system, much smaller, most likely not even a active system. For open stages in bars is what im aiming at for a general use PA system. Now how loud that would need to be is whats unknown to me? Any idea on a good way to get an Idea?
lol. Would you need to know the SPL at X distance you want to achieve probably?
And when I said "It must be easy enough" Im talking in terms of specialty equipment that would be needed that would cost lots of $ and be unavailable to me. And of coarse it would have to be reliable. Micro circuitry is something thats not going to be capable of being done by hand. Thanks for the input, ill check out those links.
