Building new HT system from scratch
Pookie
Hi there,
I now at the situation of having to decide which drivers to buy for my speakers for the home theatre system.
At the moment I have a mismatch of speakers, all home made designs. Currently the mains are the MTM Vifa P17Wj 6.5" woofers and the D25 Aluminum Tweeters, while the rears are Response bookshelf speakers. (no centre atm)
The subs are the Vifa MR 25 10", which are in two 60 ltr ported boxes.
I have two options.
1) build the rears and centre the same as my current mains, with the P17's so all 5 match.
or
2) change the drivers to another type and build all 5 from scratch.
If i went the later, what drivers would people recommend for a MTM set up with the 2 Vifa Subs.
One contender is using the peerless HDS 850467 6.5" woofers paired with either a vifa or the hds tweeter.
Are there any other speakers in that sort of price range which would be another option instead?
Thanks for any help.
