What is the general difference between a parametric equalizer like the 1124 and the way the 2310 works by crossing over and having Linkwitz-Riley filters.
Sure. In general filters can cut high frequencies (then called a low-pass filter or LPF), they can cut low frequencies (then called a high-pass filter/HPF) or they can notch out certain frequencies (called notch filters -- imagine just cutting out the range of 1,000 to 2,000 Hz, that'd be a notch filter). No filter is perfect, so there are slopes associated with how much cut there is as compared to the particular frequencies.
The L-R circuit is just a clever 4th order crossover, and I believe it's implemented in the analog domain. 4th order means that it will roll off the frequencies at 24dB/octave (this is generally good). The 1124 is all digital and its filters can be set to different slopes.
In general, and for most applications, you want to cut the high frequencies out of your sub range, and you want to cut the low frequencies out of your mains' range. The two should then blend together nicely at the crossover point. There's more to it than that, but those are the basics.
Here's a generic description for LPF from Wikipedia.
The difference between the 2310 and the 1124 is that the 2310 is a crossover while the 1124 is a parametric EQ (that can be used as a simple LPF if set up properly). That means that the 2310 is used to take in a full range signal, and then output a HFP signal (then sent to your mains' amplifier) and a LPF signal (sent to your BASH plate or your EP2500). The 1124 will not do the crossover stuff quite like that. It will take in whatever signal your send it, and it will alter it to your specifications -- it can notch a little here and boost a little there, all in an effort to get your frequency response as flat as you want (that's usually the goal anyway). If you set it up to crush all frequencies above, say, 40 Hz, then you will be using it as an LPF, although that's not really its intended usage (that's what I'm doing in one case).
Just to let you know, when we use high pass and low pass terminology, I get mixed up.
No problem; there's a lot of terminology and new concepts to be learned!
This is because my integrated amp is like a pre amp and a power amp in one box with a jumper between. It will send all the signal to the box I buy. The box has to remove highs, (is this low pass)?
Yep.
After high removal the signal is ready for either the Behringer 2250 or the Bash amp. The Bash doesn't need the box because it can accept full signal, either line or speaker out, and filter highs out itself, (low pass).
That sounds correct.
Now if I want to use a 2500, I need a signal for my stereo pair. Coming out of all of the boxes described, 2310, 1124, or 2496, is a full line signal that is able to be adjusted and reinserted to my Yamaha, yes/no?
No, you won't want to send that signal back to your Yamaha's input, or your mains. It'll be cut off for bass frequencies.
I would split the output of your Yamaha, loop one back into the unit itself and send the other one to the sub setup. I'm 99.9% sure that'll work, and it'll be the easiest and cheapest method.
If that is so then the adjustability is the comparitor, 2496 - reverb, 1124 - parametric, 2310 - Link-R.
Not sure what that means.
A Bash or other plate amps have different options built in. One of these options is high pass? Is that low power or amplified? Plugging an incomplete signal back through my Yamaha would not be that good because my satellites are full range JBL EON 15's. If I would use something without a proper return signal - I should just use a Y connector to provide one myself.
If I want or need to get a Reckhorn 400, on the back of that unit I see these connections.
Low input - connect to my pre amp out?
Speaker input - use if I did not have pre amp out?
Subwoofer output plus and minus - go to sub(s), mono only
Sat Out L and R - not sure here? it could be full signal, high passed, amplified? If not good in my case then I would use the Y connector method
All the high-pass stuff that's offered in those units may not be terribly configurable. Without reading the manuals, it'd be hard to say exactly what or how they've implemented. It may follow the frequency of the LPF, it may apply to a powered signal, or may not, etc. I'd opt for the 2310 over that business.
If you're going to be doing mostly music listening, I'd probably recommend trying to blend the sub with the mains while allowing the mains to run full range (i.e., no HPF on the mains).
Anything else bothering me? I would prefer to not just be constrained to using the 2500 for subs only. It would be nice if it could run my full range speaker set too. I suppose it can if I do it all different.
I think you're pretty much going to have to dedicate that amp to sub duty or mains duty -- you'll have to pick one. That's because the signal that's feeding the amp will apply to only one or the other. Unless you go to passive crossovers, and I don't think you want to do that.
