Building An HTPC And I Ned A T.V. To Go With It
Polygon
Polygon
So, I upgraded my main computer. So, I got a bug up my *** to use the old parts to built an HTPC and retire my X-Box 360. With that I have an old CRT that isn't even capable of 420p. So I need a new T.V.
I'm looking for something under $1,000. I sit about six feet from the T.V. so a 40", maybe 42" would fit the bill. It also has to be able to hook up to a PC without issue. I've seen a couple that have some issue with the PC connection. In the price range I've found plenty of options with 120Hz which I don't want any set at 60Hz. Also, I decided to go with LCD.
Here are a few that I've found that caught my eye:
Samsung LN40A630.
Samsung LN40B630.
Sony BRAVIA V-Series KDL-40V5100.
Let me know what you think and post up any suggestions you might have, like maybe what you're using with your HTPC.
