Headfoot
I'm looking to research into how to build a speaker cabinet (tower style, sealed as well). What are some good resources (print, internet, magazine, anything really) that I can start reading to learn up on this? Thanks for the help!
Speaker building, a rewarding hobby
Dear Headfoot,
Welcome to the realms of the "amateur speaker builder".
I commend you to want to educate yourself before wasting money and time. A loudspeaker, seemingly so simple, is in fact extraordinarily complicated. Designing and building a good speaker is challenging and rewarding. I have been doing it over fifty years now.
These three books from Old Colony sound labs, a division of audio xpress is a good place to start. Vance Dickason's book is particularly outstanding.
http://www.audioxpress.com/bksprods/products/bkaa67.htm
It would also be a good idea to get a subscription to Audioxpress. That is the merging of three magazines by the same publisher, Speaker Builder, Audio Amateur and Glass Audio. You might want to pick up some back issues of Speaker Builder. The reason for the merger was declining sales. Believe it or not, there is much less amateur speaker building than there used to be. I say it's time to reverse that trend! There has never been a better time to start designing and building speakers. More is known, and there are numerous computer modeling programs that make things much easier. With the cost of fitting out a home theater with eight speakers including the sub, you can save huge amounts of money. However if you don't learn to design it right, and build the speakers skilfully the results will be very disappointing.
For your first project, I would recommend a two or two and a half way design. Do not start with a three way. Do not have any preconceived ideas, about whether the cabinet is ported or sealed. Both designs done well, work well. Whether the enclosure is ported or sealed is dependent on the parameters of the drivers you choose. Some work either way, others better ported or sealed. There is a strong tendency of most of the current offerings of OEM drivers to be optimally loaded ported.
You can always choose to look into transmission line loading, which I have always favored. There are very few commercial examples, because of the cost of building them. However this gives the amateur the opportunity to best even the high end manufacturers.
Those of us who consider ourselves members of the speaker building community will be glad to help and encourage you.
Good suggestion
Jinjuku has made another good suggestion. However you might want to see what you can do with your own work. You will learn much more that way, but the mental effort will be greater.
I would add the Madisound kits. They have some of the best available.
http://www.madisound.com/kits.html
If funds permit, the Thor kit offered by Maidsound is one of the finest speakers available today.
http://www.madisound.com/thor.html
Good Luck, and let us know how you get on.
Guiria
Guiria
You may want to try a few already designed DIY speakers:
Zaph Audio
RJB Audio
Part Express
Just a few to get you started.
I would second the recommendations here...
Zaph's driver comparisons and speaker builds are really interesting to read about.
Partsexpress offers some good information on their DIY resource pages and project showcase.
DIYaudio.com is another useful resource.
Guiria
Guiria
If you do decide to get a book or two I would recommend what audioxpress says...
Follow the recommendation of speakerbuilding 201 first then the others.
I can comment on Loudspeaker Design Cookbook (LDC) in that it is not a cookbook at all but a book about speaker design theory. There are a couple of chapters outlining some speaker designs but mainly it is a book about principles, and theories of speaker design.
A cookbook would say:"Take woofer A, tweeter B, and add XYZ for crossover parts and place in a .25 box. If your highs are a little runny then add more of Y to your crossover."
LDC is not like that (I bought it expecting such a book and therefore was a little disappointed).
I have gone back several times to the book to reference and look up certain aspects of speaker design so I am glad I ended up with the book, just not what I was expecting initially.
Runamuck
Also try diyaudio com
They do more then speakers there. If you interested in tube amps its a good site as well. I cant post links yet have to raise my post count.
Also try this for this a starter project. Really good for 2 channel listening. High end good.
www ejjordan co uk
I am in the middle of building mine for my office where I do most my listening, mostly sports talk radio or some BBC zepplin sessions.
