JohnnyFever said:
Thanks again,
I am actually thinking of wiring it myself (hopefully I can LOL). I have been talking to an installer but they are in another city about 8hrs away. They haven't gotten back to me on the price but they will be lower than anyone in this area. I am just trying to see if I would be getting in over my head if I was to do it myself. I prewired the last house we built but it was just running a few wires for the rear speakers. I do have 2 receivers so I could put one in the master bedroom and run the wires from that one to the master bedroom and master bathroom and have the second receiver in the main family room to run the speakers there and in the kitchen.
If you will do that work yourself, make sure the contractor knows or might get hassled about it. Do it after the 120V is wired so you can wire the other side of a bay or further away, not on the other side of the stud with the 120V.
If you are setting up a Home Theater and considering a sub-woofer, they are powered mostly and you will need a 120V outlet where you will set it up. Ceiling speakers will not do you justice for Home Theater. It is OK for background music at dinner, etc.
You would also need signal cable to that sub and an RG type cable can handle that task. Depending on where the TV's are and where the DVD players will be, you need video cables, etc.
You do have a big task ahead of you designing this properly. Wiring is the least of your problems.
Also, as was stated, wire is cheap when you rough it in. Remodeling when the house is complete gets expensive.
You might consider some design help?
