I am not 16 but too young in the filed to give you advice.
You will get an answer, but you need to precise how much you can put on your HIFI system and where you plan to use it (room size). Maybe what you like to listen to also...
Good luck.
I want a Hi-Fi now, Docks are too over priced for there worth.
I have about £100 atm but I will regularly save up until I can buy my next unit. Currently found these, which I think are well worth there money, so I will save and get an amp as well
TEAC LS-H265 2 Way Speaker System: Amazon.co.uk: Musical Instruments
I will be using in my bedroom and maybe my front room/hallway depending on where my Apple Mac is and whether my parents are home. My bedroom is around the size of 2 double beds with very little space left, not enough to open my door. The speakers will be on one side of the room facing me in bed I would imagine as it would seem pointless facing somewhere else.
My music tastes are; Drum and Bass, House, Deep House, Dance, Pop, Indie Rock, Dubstep, Garage.
Thanks
