"budget" CDP/DAC upgrade
brad1138
brad1138
The last place I need to upgrade for my 2 chan system is the CD Player/DAC. I am very happy with my Pre amp, amp & speakers. I am just using a standard 5 disc Sony CDP as the transport and a Soundstream DAC-1, which is a mediocre DAC, but still better than what the Sony has. From reviews I have read it is better than built in DACs in Yamaha & lower end Denon.
I have heard a lot of good (if not great) things about the OPPO bdp-83, that might be better quality for CDs even w/o a separate DAC, or if needed, with a separate DAC. I would be able to utilize its BluRay abilities also, right now I use my PS3 for my BDP.
I would probably like to find something used, to save money, but what do you guys think?
Thanks,
Brad
Thanks,
Brad
If or when you have a need for a BD player, the Oppo 83 seems to be a very nice player and will do well with Cds too. Not sure if there are any used ones yet though. Or, even a less expensive BD player will do you well, like a Panny 60?
I doubt replacing your Sony CD player will gain you anything. Since you have a external DAC it seems the 5 disc player has a digital output? If so, does your preamp have a DAC? Use it. Can that PS3 take a digital input from the player? I would not be infatuated with external DACs. No mystery to them.
brad1138
brad1138
Yes the Sony has optical out which runs to my DAC, the preamp has no built in DAC. I use Audioquest Ruby interconnects from the DAC to Preamp to Amp.
I am just looking for the best sound/performance for my price range (probably about $500) If it is a used stand alone piece or separate transport/DAC it doesn't matter. Some one on a different site recommended a used Rega, after Googling those, they do look nice.
