Hi,
For the past ten years, I’ve been using Energy C-Series bookshelf speakers. Recently, I saved up and ordered the S300 mk2. I’ve had a Peachtree Music Box for about nine years, but the volume potentiometer is failing—it only works when fixed in one position. Finding a replacement in the US is quite a hassle since it’s not a standard part.
I plan to use the Peachtree as a DAC/preamp while I have a Sonos Connect for multiroom audio and a CD player connected as well.
I’m considering a few alternative amplifiers, including the XtZ Edge 300 and the Emotiva Bas A-100, which I can get second-hand for around 300 Euros. I currently have the Emotiva on loan, and it sounds good to me. I also spoke with the owner of Buchardt, who recommended Holographic Audio and Primare (though they’re pricey) as good matches for their speakers.
My room size is a bit of a concern—it's 6m x 5m—so I doubt that expensive gear will make much difference, especially since I can't listen at high volumes.
I have a budget of around 1500 Euros. Does anyone have the S300 mk2 and can recommend an amp they’re happy with?
