All, years ago I ran the Kinergetics/BSC subwoofer, SW-100, as part of a 2-channel system. The subwoofer 'package' consists of the subwoofer and an external amplifier.
Life went on, and I no longer used the subwoofer: put into storage. Cut to 2008, and I have the Cambridge Audio 540R (version 2) a/v receiver. So, I am wondering if I can use the Kinergetics package with the 540R?
If I can use it, how do I connect it?
Clearly I cannot use the modern method: sub-woofer line-out on the Cambridge into the subwoofer amp. The sub-woofer amp has its own "Right" Out and In, and "Left" Out and In connections. Unfortunately I do not have the specs on the SW-100 amp. Google search does not get me very far.
As well, is sorting out all of this worth it? Or do I bite the bullet and buy a modern sub? I remember the BSC/Kinergetics sub as being of high quality, so I would like to use it if possible.
All input, advice, suggestions gratefully received! Thanks.
