well, "yea, get the sst" is the obvious answer... i know that...
however, there's a pretty significant price difference between the 2 (talking used)... probably around 6-8 hundred dollars... i have listened to the 4bst's hooked to "my" speakers (although not with my receiver as the pre-pro), and it really sounded good, even to my ironclad ears...
my current setup is a yamaha rx-v750, with b&w s603s3 mains, s600s3 surrounds, lcr600 center and asw600 sub... usage is about 90-10 2-channel to ht...
i am also planning on adding a "decent" (but not really expensive) cd player (cambridge 640c? maybe something a little better in the used market? suggestions?) to the front end and run that "straight through" the yammy...
ideas? comments? am i off base here in thinking that i can survive with the yammy as the pre-pro for the time being, until i can do that upgrade? it really isn't objectionable for ht usage... it does that job adequately, for the usage it gets...
i know that either of the bryston's is overkill (although some may say there is no such thing as overkill
) on my existing mains, but i also know that there's a speaker upgrade out there someday...
i'd like to get out of this for around 2.5k (for both pieces), but would be willing to stretch that a bit to go for the sst if it would be a significant difference...
help. i'm driving myself (and swmbo) crazy with overanalysis here...
i'm pretty much sold on the bryston as the choice... just which one...
