<!--StartFragment-->I recently purchased a used 4bsst.
Last night when I turned it on, it blew the circuit breaker to the power to my upstairs room.
I hooked up my old amp and everything was fine.
Im wanting to use it as a 2 channel using unbalanced (RCA) cables.
(1) I initially plugged it into a power conditioning strip with other devices plugged into the strip. The strip is then plugged into a quad outlet will all four outlets being used.
(2) I then plugged it directly into the outlet by its self without the conditioning strip and all the other devices disconnected from the quad outlet.
Both scenarios resulted with the breaker being blown.
Im using a Cary Slp 98 F1 preamp.
<!--EndFragment-->
