Bryceo
Bryceo
Is it worth getting broken plasmas fixed my friends plasma fell off his wall unit
Adam
Adam
That depends - what part(s) broke? For example, is the display cracked?
Adam
Adam
My guess is that it's not worth it. Once you add in labor to the cost of the panel, a new TV will probably be cheaper - but that's just my guess based on other experiences. Your friend could always call around and get price estimates, and then decide if it's better to just buy a new TV.
Bryceo
Bryceo
Yeah I was under the impression it was cheaper and esey to go
Out and buy a new tv with the way
Prices are now verey cheap
BMXTRIX
BMXTRIX
While it depends on the TV itself, for the most part you can count on the TV being far less expensive to replace then to repair.
Especially if you are talking about a TV in the 50" or under size range.
Then, of course, you need to mount the TV so it doesn't fall off the wall (!!!)... How the heck did that happen?
