And this coming from a man who uses two Funk 18.0 subs with his Salon2s (-3db @ 23Hz) running full-range. Oh yeah, and the same guy who got a little bent out of shape because Funk said some confusing things about the 18.0's maximum output versus the 18.3's, which, incidentally, is on the high side of 120db. Okay...
FMV's B&W is a ported design with a -3db point of 30Hz. The 2000+ watt products are sealed designs in relatively small enclosures with heroic drivers and usable output at 15Hz. If you want that 120db of advertised output, 500 watts won't do it. If Funk put a 500 watt amp in the powered 18.0 and Ricci tested it and found its output limited to, say, 105db, wouldn't you feel upset (even though you buy the passive versions)?
Don't mind me, I'm just rattling your cage because I'm in a weird mood this morning.
