pjoseph
Is this bracing ok or will it restrict air from the port?
This is not complete just learning how to use google sketch.
avaserfi
avaserfi
It is hard to tell from your picture, but if you ensure that there is nothing within about 6" of the port openings (inside and outside of the sub) and you will have no issues with air being impeded.
As far as bracing goes, if you plan on using this as a typical subwoofer, crossing over no higher than 100Hz. There will be no substantial panel resonance issues if you put another similar cross brace in above the driver and connect the two with a brace running top to bottom in the sub.
Similar to this:
Note how the bracing is on all axes XYZ, this allows for maximum efficiency.
What driver are you planning on using and what are you intended cabinet and port dimensions?
-Andrew
pjoseph
Yes I know more bracing I plan on putting another above and then one up and down.
Just wanted to do one and make sure it is ok before i do the rest .
Thanks
mike c
mike c
and double check your port area ... it looks mighty small in that sketchup
pjoseph
This is not a calculated box i am just learning how to use the google sketch.
My goal was to just find out if my bracing is acceptable.
Thanks for your help
