BP10, BP7040 and Mythos one towers
Deval
I have the 7040 as fronts and BP10 as surround... I saw some mythos one towers for cheap and was considering buying them just because I see them so cheap.
My question is how good are they and would you replace the 7040 or BP10s with them?
slipperybidness
slipperybidness
The Mythos line is really more about the form factor rather than pure performance.
I likely would not make the swap.
My gut feeling is that you won't get significant improvement.
If your system already sounds good, just let it be. :D
How cheap is it anyway?
snakeeyes
What subwoofer do you run? I removed my BP10b surrounds and replaced with SR9040 and crossover bass management to 100hz to the subwoofer (Rhymik LVX12). I kept BP10b mains and PM500 center. Yes I’m running the front 3 full range. I know most people don’t do that but I’m happy. :)
