Bought my first turntable, but i have no speakers.
MortenSJ
Hi
I just bought my first turntable.
This guy, a Sony PS-LX300USB. I know it's a cheap one, but i'm not going to be listening to any loud music. I live in a small studio so i think that will be enough.
I need some speakers. Just some cheap bookshelf speakers.
Is it true, that i can just buy some bookshelf speakers, and then hook them up directly to the turntable as there is a built in amplifier?
I want to get some from best buy if possible, but i'm not sure if i need anything else.
Thanks in advance :)
markw
No, well mostly no. How would you control the volume?
The turntable might have a phono preamp built in but you still need to amplify that signal enough to be able to drive speakers. That will require a power amp of sorts.
You would need to search for amplified speakers. These have built in amplifiers.
These are the current go-to amplified speakers recommended nowadays but are generally used for computer speakers. This appears to be the only similar item Best Buy offers. Go the re and search on "powered speakers" amd see what else pops up.
You might be lust as well off getting a receiver or integrated amplifier and standard, non-amplified speakers as these are much more common and will afford you more choices and flexibility.
If you want meaningful suggestions on this you might want to state a price range you're expecting, or hoping, to spend. Remember, you get what you pay for here.
Keep in mind that you can get a full stereo receiver starting sround $100, or a small integrated amp for $50 or so, and still have a tremendous selection of non-powered speakers for the additional $100.
