Bought a Samsung HW-N850 Soundbar, I have a a couple questions...
BARRACUDA1968
I'm using it in my living room to watch TV.
I have my cable box fed to the soundbar and then an HDMI fed to the TV. I have a Vizio smart TV but it does not have an ARC input. When I watch cable tv it works fine but when I watch Netflix I don't get any sound. Why is that?
Do I have the sound bar hooked up correctly?
Danzilla31
Most likely you would need ARC for the TV to send the audio back to the sound bar.
Does it have an optical input on the sound bar? It should if so you can run an optical cable into the sound bar from the tv should solve the issue
