My brother was over for the holidays...
Showed him my Infinity sub woofer build that Jinjuku helped me with...
He was impressed...so much he went back home and dug out a couple of woofers he had sitting on the shelf...
He has 2 boston acoutics 10.5 LF pro drivers...
If they would make a decent sub, why not use them...
He wants to build a dual oppsed sub with them...
He has a Daton 500 watt plate amp for power...
His question, are they worth using, if so what would the dimensions of the box be...
He would prefer a sealed setup....
i told him I would ask the collective gurus....
Here are the specs...
10.5LF (4Ω)
Fs - 34Hz
Vas - 1.24ft3
Qts - 0.53
Qes - 0.57
Qms - 7.8
Cms - 255µm/
Mms - 86g
Sd - 315cm2
Voice Coil Diameter - 51mm
Re - 3.1Ω
Le - 0.55mH
Xmax - 8.5mm
Peak-Peak excursion - 35mm
Reference Efficiency - 0.25
