Bose and Pioneer hook up
F
FelSant13
I want to connect a Bose Powered Acoustimass 9 speaker system with a A/V receiver Pioneer VSX-524-K , I'm having a problem with the connection at back of receiver.Would appreciate any help n thanks
LOL thought you were going to have some info on a joint marketing scheme between them :)
We don't do a lot of Bose, and many Bose have proprietary connectors or odd amplifier setups via their bass modules. I tried the Bose site but it is too convoluted to spend much time on.
Don't even try. Bose is ONLY designed to connect with Bose. If you buy Bose you deserve a pile of grief.
Trebdp83
While some Acoustimass systems such as the Accoustimass 6 Series V or 10 Series V are designed to be connectable to 5.1 receivers, the 9 is designed to be used with a bose controller/disc player.
F
FelSant13
Yeah, I have it, but I wanted to used the Acuostimass subwoofer n satelite speakers with the Pioneer receiver.
F
FelSant13
thanks.
that bad ah?
thanks.
that bad ah?
Yes, that bad. At least you have been saved from listening to abysmal sound. Look on the bright side! Ditch it, and get something worth listening to.
