Bose Amp 1V sa 1 help
Don Morada
Need to find out about the trigger to turn on this amp . How much voltage , amperage , and which pin to connect it to .Any help would be greatly appreciated.
Bose is all proprietary and units are only of use in their own universe. They are in general junk and to be avoided.
This is what the manual says about your unit: -
The Lifestyle
stereo amplifier is designed for use with Bose non-powered environmental speakers or
Bose non-powered accessory speakers ONLY
Good luck! Triggers are 12 volt as a rule, but you can bet with Bose it will be something different.
Eppie
Eppie
There is no data anywhere on this. The back of the amp has what looks like an 1/8" jack labeled system control. That should be your trigger. There is also a trigger line built into the DIN jack. It is anyone's guess as to witch pins and what voltage. Someone with service experience could open the amp and figure it out but for a general user what you are trying is not recommended.
