Could I use my bose 901 series VI as regular speakers (without the equalizer)?
C Cuong Nguyen Audiophyte Jun 13, 2016 #1 Could I use my bose 901 series VI as regular speakers (without the equalizer)?
M markw Audioholic Overlord Jun 13, 2016 #3 j_garcia said: Yes you can, but it may or may not sound right. Click to expand... That's a gross understatement.
j_garcia Audioholic Jedi Jun 13, 2016 #4 My understanding ws the EQ was for the low frequencies because of the angle of the drivers, it is required to reduce room modes. So the speakers should work without the EQ, but they will be extremly room and placement dependent then.
M markw Audioholic Overlord Jun 13, 2016 #5 That eq also applies a serious amount of bass enhancement. No matter how many there are, a 4 /12 driver can only produce so much bass without help.
j_garcia Audioholic Jedi Jun 13, 2016 #6 markw said: That's a gross understatement. Click to expand... My original response was no you can't but technically, you can
