bpape said:
Or try shifting your listening position about 6" to one side of center in the width dimension. People pay attention to the length and forget about the width.
If it turns out to be height dependent, a 4" panel directly over the listening position can also help.
Bryan
That might work...but...
The {3,0,0} mode (axial along the length) is 80.7 Hz. This would be my guess as to the main cause of the problem. When the room starts resonating at this frequency, everything else will start vibrating right along with it. This sort of thing is not uncommon. There is also a tangential mode {2,1,0} at 81 Hz, which is probably being excited at the same time, exacerbating the problem.
Note: Using CARA, I roughly modeled your room. I have attached a good graphical representation of the spatial sound pressure level response - at ear height - for 80 Hz based on the information you've provided. The "balloons" show the rough locations of your loudspeakers (blue) and the listener (yellow) in the room. The x- and y-scales are the room dimensions in meters and the z-scale is a relative SPL scale for ear height in the room. As should be obvious, the listening location corresponds to a significant 80 Hz SPL peak.
I would concur with sploo - a good tuned absorber would help take care of the problem. I would suggest one of the perforated variety. This might help take the edge off that frequency. If the resonance is that bad, you will probably need quite a number of small-to-medium sized absorbers, or several large absorbers. I usually suggest building a few small ones, placing, evaluating, building some more, etc. - an iterative process.
You might also consider:
- Moving the loudspeakers closer to the wall in 6" increments. According to my calculations, you should be able to find a spot somewhere around 3.5' from the front wall that won't excite the 80 Hz mode at all. Of course, don't bank on this - it is theoretical. But the same calcs showed a strong spike at 80 Hz, right where you've indicated there is a problem. And you may discover that 54 Hz suddenly gives you trouble...
- Spikes will enhance any resonance occurring between the loudspeaker and the structure. If this sort of structural resonance coincides with a room mode, thing will get worse. IMO, lose the spikes. (Please note: I'm not a fan of spikes.)
- Experimenting with your GIK panels could also improve things. Changing the airspace depth behind a panel (up to the thickness of the panel) could improve their performance in the 80 Hz range.
- You could also modify some of the GIK panels - or purchase more of them
- by (re)facing them with the right type of perforated board (as alluded to above). This way, they can be tuned to the desired 80 Hz range.
If you're literate with Excel, there's a good spreadsheet
here ("Porous Absorber Calculator") that can help you calculate the right design of perforated board. (And keep in mind that there is more than one design possible.)
