Is there any way to play process of elimination when every one of my speaker considerations have excellent reviews? Especially when it is not possible for me to listen to each one due to lack of decent shops in the area?
I want to use the speakers that I buy for music AND movies.
I will, eventually, be buying a subwoofer. Which makes me wonder, would it be overkill to buy the NHT SB3's if they only improve on the SB2's on the low end of the frequency range and I'll have a sub to pick up that slack? Should I try and choose speakers that are more generous at the other end of the frequency range, even though they all go up to and beyond 20kHz, and that is as far as the human ear can hear anyway?
Are the NHT speakers as good at reproducing music since they are technically in their home theater line?
Are the SB3's that much better than the SB2'S? The Paradigm Mini Monitors over the Titans? The Axiom m22ti's over the m3ti's?
Should I avoid the incredible Monitor Audio Bronze B2's and the Wharfedale Diamond 9.1's because of their 6 Ohm impedence if I am not going to spend a fortune on a receiver?
Who wants to play a game called "rank the speaker"?
I really need to eliminate some of these and purchase speakers and move on to the next thing!
Now Hear This! SB-2 –
51Hz to 22kHz
86db
150 Watts
Now Hear This! SB-3 –
39Hz- 22kHz
175 Watts
86db???
Paradigm Titan –
60Hz to 20kHz
86 db
100 Watts
56Hz to 20kHz
87 db
100 Watts
Ascend Acoustics CBM-170 -
69Hz to 20kHz
89db
200 Watts
Axiom M3ti –
60 to 22kHz
88 db
175 Watts
Axiom M22ti –
60Hz to 22kHz
89db
200 Watts
Energy C-3 –
46Hz to 23kHz
89db
125 Watts
42Hz to 22kHz
90dB
100 Watts
*6 Ohms*
50Hz to 24kHz
86db
*6 Ohms*
