I originally posted this in the "Amps, Pre-Pro & Receiver" section (although the thread should've started here, I suppose) because I was thinking of getting an active crossover for my living room 2.1 system. But, after being informed that it probably wouldn't solve my boundary effects issues, I have to look at taking other measures.
Well, here's my system. Boy, those photos sure look grainy when they're compressed that much. So far, I've been able to keep my wife from putting more stuff on the shelves beside the speakers. As you can see, putting those speakers on stands will stand out like a really sore thumb. There's just no space for them. The other end of the room opens up to the hallway and the dining room.
I still have to build a cabinet for my components. It'll go directly opposite the present position, to where the end table currently resides. The subwoofer will stay where it is.
So, it boils down to the following options:
1) Buy or make wall-mount brackets for the speakers and mount them out on the side walls.
2) Put some acoustic panels behind the RC-10s. The space is about 16" x 32", but the treatment could only be about 3" thick max. Would that be of much benefit? I just don't want to go through the expense, time and effort to put something in there that won't make any practical difference.
3) Buy in-wall speakers. The ones I have in mind are the Axiom M-22 in-walls. They have a backer box already, so I wouldn't have to mess around with that. I'm thinking the dual woofers would do a better job of moving the air in such a large space. I could probably convince my wife that the expense is worthwhile, since I'll be freeing up the shelf to do whatever she wants with it.
There are two concerns with this option though.
These are the exterior walls, which are not insulated
, as it's an older house, built of brick. Brick requires an air space so that any dampness, due to condensation, on the inside face of the brick can dry out. Makes it easy to run wires though
. It gets pretty cold here in the winter - should I be concerned about the drivers getting quite cold? I should probably ask Axiom about that...
Plus, installing in-wall speakers would require that the tweeters be very high up the wall. I could build a wedge-shaped box frame to angle them down a bit.
Those M22's really appeal to me though...
4) Leave well enough alone. Maybe I'm just being anal in thinking that I need to do something to improve my SQ. I've looked at a lot of the photos of members systems and many of them have subwoofers in corners and floorstanders just a few inches from the back wall. They don't seem to complain much about SQ, due to speaker placement.
Any thoughts?
