It has been discussed numerous times
Monopole speakers as surrounds works great, and is the preferred method for me personally, especially if your room does not allow the correct placement of bi/dipole surrounds. I like the more localized sound of a monopole. Bi/Dipoles give you a more "ambient" surround effect that is less directional. Monopoles do not, and in most cases should not be pointed directly at the listener, in particular if they are fairly close to the listening position. You can achieve a similar diffused surround effect with a little experimentation with the orientation of monopole surrounds. It varies depending on what you are listening to, as well as your specific room/setup, how effective each will be.
