JennAir said:
All the usual suspects listed once again.
Here's something different. I use these for the rears in my HT, but I've also checked them out for two channel. For the price, the other brands either sounded bright and harsh or lacking life. Definitely worth looking in to.
http://www.us.alegriaaudio.com/Ling.htm
these are the spec's for the above aforementioned speakers, and IMO not impressive.
Description
Extremely wide and accurate frequency response (+/- 3db 60Hz to 30kHz) measurements
8 ohm nominal impedance
Quality crossover parts including air core inductors and film and foil polypropylene capacitors
Oxygen free stranded copper internal wiring
All soldered connections
Compact design 12"H x 7.5"W x 10"D
Amazing detail, depth and imaging for the budget-minded audiophile
100 watt peak power handling
85 db/1w sensitivity
Magnetically shielded for use near televisions or monitors
Grade A real wood (not vinyl) veneer inside and out to prevent warping.
