Blutooth PA systems. LOUD/QUALITY
TetherStorm
I have used a few blutooth PA systems but there are already so many brads and models to choose from. I am looking for a very loud, quality sounding, Blutooth PA speaker with a long lasting battery life. I have done some research but I really need experienced advise. I can not stand buying things that...……. SUCK...……… lol thanks for the input. I am new to the forums and look forward to see what information you may have.
BMXTRIX
BMXTRIX
What will you be using it for? Where will you be using it? What is your goal? What is your budget?
Most quality PA speakers aren't run from a battery as the louder anything gets, the more power it must draw, especially for something of high quality. So, while I have one of those portable Bluetooth speakers that I use when I'm at the basketball court, it is neither that loud, nor of very high quality. The battery just isn't sufficient to drive it and the drivers aren't designed for it.
So, perhaps a bit more information. Certainly, from what I've seen, almost all people that need actual quality go to a good powered (plug-in) system, and then they actually use wired connection or professional grade wireless mics.
TetherStorm
I have seen some Bluetooth cabenets get upto 700 watts, and have 10 hour life. I was thinking closer to 1000 watts I know it will be heavy, most likely a rolling cabenet. 25 - 45 lbs.
It is considered a public announcements blutooth speaker.
I would like good base considering most come with at least 10' subwoofers.
I can spend $300, a mic would be a plus
BMXTRIX
BMXTRIX
I think, in fairness, you are going to find out the hard way just how much manufacturers just lie through their teeth on specifications. They are completely meaningless unless you are going to quality manufacturers. Wattage and sound quality are meaningless measurements. Plenty of Bluetooth speakers out there, but as I said, actual quality units with significant power, tend to only come from higher dollar plug-in units.
I do wish you luck.
