Blurring motion problem.......
cerwinmad
cerwinmad
I have a samsung 32" widescreen CRT, 100Hz digital, HDTV. i have my pioneer 490v connected via component out to the screen and its set on progressive scan. there are two component inputs on back, one is labelled DVD but only accepts 480i, 576i so wont work with progressive, The other is labelled HDTV and accepts 480p, 576p and 1080i, this is the one i use. Its an awesome picture, but occasionally im watchin a dvd and the image will blur on movements and motion. it only lasts a while and if i pause the movie for a few seconds then resume it stops. i thought it was the digital noise reduction on the screen so set this to off. Any thoughts or theorys?:confused: it happens randomly. i looked at onscreen display when it happens and tracking is in normal range. any ideas are much apprieciated.
