Blue-Ray to Reveiver audio help
Richard Anderson
Setup: projector with only 1 Hdmi cable running to an Hdmi switch (4 in 1). Hdmi running from the switch to my blue-Ray. All that works fine and here is where the issue starts. I have a fire stick and my DVD player has an Hdmi input so I'm using this for my fire stick. All works fine but I also have a receiver I'm trying to get all of this sound to. I don't believe the DVD player has any audio outputs as it was part of its own surround sound but the receiver has more power. I've tried running an Hdmi to the receiver and have the fire stick plugged into the receiver. Couldn't get that to work or know if that's even a real thing? I need help figuring this out. I've listed my DVD player and receiver info below. Is there any other options to get my DVD player and fire stick to work through the receiver for sound?
I know the reveiver and speakers work fine because I've hooked up another DVD player (no Hdmi input for the fire stick) and it works just fine.
Maybe an easy fix but I can't figure this out.
LG LHB326
Onkyo HT-R667
agarwalro
agarwalro
Just move the Fire Stick to any available HDMI input on the receiver. I have it running this way without issue, as probably a significant percentage of forum members here.
Richard Anderson
Thanks very much for your response. I have tried this but couldn't get it to work. I'm sure I'm just doing something wrong on the part but it still wouldn't resolve the issue of my DVD player running through the receiver. I've tried this with no luck but should I be able to run an Hdmi from the DVD player to the receiver? Would the run the audio through the receiver for the DVD player?
You should be able to use the hdmi out from your disc player to your avr and use both the audio and video via your avr. Just exactly what is all the gear and how do you have each unit connected now? Have you checked to see if you need to assign an input in your avr for the type of input being used?
