Hi all
I have been eyeing the BK Electronics Gemini II for some time now. The only problem I have is, it might be too tall to slid under my cabinet, which is the only reasonable place for it in my apartment. My cabinet is 355mm tall and Tom, from BK, tells me that the Gemini II is 357mm with the nylon/rubber feet removed. He also tells me that there is a set of steel feet below the nylon/rubber feet which "cannot be removed" as it raises the sub to its desired height.
What I am wondering is, can these steel feet actually not be removed. It is just a matter of 2-3mm below which the sub would slide under my cabinet. I was hoping to be able to remove all the feet and put some spikes slightly shorter so as to be able to make it slid underneath my cabinet.
Could anyone who already owns the Gemini II confirm its exact height? Also, can I remove all every support in the bottom to screw my own set of spikes? Note that they will rest on my concrete floor. I was also wondering if I could lay it on its side. But I guess it will go both against its performance and the aesthetics.
Your help is much appreciated.
Cheers!
