.BIN files, what is the problem with these things?
Seth=L
Seth=L
.bin files are making me super angry. I don't think I have ever been so angry about a computer problem than I am right now. I downloaded a .bin file which requires Poweriso to "unpack it" or whatever. So I download the program and register. I go to unpack the stupid thing and low and behold I still can't utilize the file. It is now recognizing the file as a poweriso file, but I think it is supposed to be an .avi file. Please, for the love of sanity, help me figure out why I am not as smart as the computer.:D
avaserfi
avaserfi
.Bin files are generally like an .ISO file made to be burned to a disc and than utilized. If you want to unpack it on your computer I suggest getting ISOBuster. It always did the trick for me :).
Seth=L
Seth=L
It worked, but through all the BS compression and decompression it lost it's quality.:( I wish they would leave the compression alone, it didn't save time or much space.:confused:
Thank you for that program, it works tons better than the Poweriso junk, I hate that program.:mad:
avaserfi
avaserfi
No problem. You could try to burn it to disc using something like nero (thats what bin files are actually designed for) but I doubt it will make a difference I have a feeling that the original .avi file wasn't the greatest quality to start with.
Seth=L
Seth=L
Probably right on the quality. I hate Nero. The software for it came with my computer and I removed it because it was annoying.
avaserfi
avaserfi
Really? What program do you use to burn your material? Nero is what I have been using for years and I love it. It gets everything done quickly and easily.
satish536
try imgburn ....but it only burns images !
MDS
That was my first impression of it too when I first bought a copy of it a few years ago. I was used to using Roxio Easy CD Creator and the Nero interface was just more complicated to do even simple things.
Now I'm used to it and it is what I use although I don't burn CDs very often anymore.
mike c
mike c
i started with Roxio too ... it came with the burner drive ... then the succeeding drives came with nero too. I hate change, so if there's no problem, I stick with something. (like a Koala bear)
avaserfi is right, I burn the .BIN "image" straight to disc using Nero or I use DAEMON tools to make a virtual disc on the HD.
Seth=L
Seth=L
In regards to using nero or some other burning program. I don't use them because the computer is connected directly to my TV and sound system, so I don't have a need to burn.:D
1
10010011
.BIN files usally come with a .CUE file that is a sort of "cue sheet" for the file. (tells what files go where, etc)
Maybe the .cue was bad?
avaserfi
avaserfi
You would be surprised how often bin files don't come with a queue sheet as lately they have been made useless due to more advanced burning programs not needing to be told what to do by the cue.
