Bigger, Better, More Sound?
SMcRae
I thought I was going to upgrade my audio/video equipment last year. I’m happy with the video part but I still prefer listening to my old stereo from 1972. It is – Pioneer Sx-727 receiver, Pioneer CSA-700 speakers, Dual 1218 turntable. When I crank my new stuff up it doesn’t come close to the old stuff that drives the music right into you and fills you up with it without distorting. I want to achieve that with my new stuff if it’s possible and maybe you folks can tell me what I did wrong and how I can fix it. Here’s a list of the new stuff and some of the specs which have little meaning to me -
A/V Receiver - Onkyo TX-NR3007
Power Output -
Front L/R 140 W + 140 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Center 140 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Surround L/R 140 W + 140 W (8 ohms, 20 Hz–20 kHz, 0.05%, 2 channels driven, FTC)
Dynamic Power 320 W (3 ohms, 1 ch) 270 W (4 ohms, 1 ch) 160 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.05% (Rated power) Damping Factor 60 (Front, 1 kHz, 8 ohms) Input Sensitivity and Impedance 200 mV/47 k-ohms (Line) 2.5 mV/47 k-ohms (Phone MM) Output Level and Impedance 200 mV/470 ohms Phono Overload 70 mV (MM, 1 kHz, 0.5%) Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode) Tone Control ±10 dB, 50 Hz (Bass) ±10 dB, 20 kHz (Treble) Signal-to-Noise Ratio 110 dB (Line, IHF-A) Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Speakers - Front L & R - Vienna Acoustics Bach Grand (wired normal - the only way possible)
2-way Crossover, 7” Mid-Woofer, 1” Dome Tweeter
Impedance (4 ohms)
Frequency response (35-20000 Hz)
Sensitivity (90db)
Recommended Amplifiers (50-300 Watts)
Speakers – Center & Surrounds L & R – Vienna Acoustics Waltz Grand
2-way Crossover, 2x 6” Bass/Mid-Range, 1” Dome Tweeter
Impedance (4 ohms)
Frequency response (70-20000 Hz)
Sensitivity (91db)
Recommended Amplifiers (25-180Watts)
1-Subwoofer – Martin Logan Dynamo 500
I’d rather not start all over and hope there is a simple not to expensive solution. Any criticism, advice and suggestions will be immensely appreciated.
Thanks…Stu
SMcRae
could someone please instruct me how to delete this thread? It's a duplicate and makes me feel silly!
Thanks...Stu
